Quite the opposite is actually the case! Motorcycle oil is usually much higher in ZDDP (Zn and P mainly, but also often Bo or Mo) as well as in detergents (Ca) and can often be an excellent choice for small engines.Motorcycle oil is not the same as car oil....it lacks friction modifiers
The friction modifiers being referred to here are the ones that are required to get the "energy conserving" starburst. The same ones that hurt wet clutch performance. These oil listed above are surely JASO MA certified for wet clutch performance. Small engines dont need energy conserving oil, they dont need to retain wet clutch performance.Quite the opposite is actually the case! Motorcycle oil is usually much higher in ZDDP (Zn and P mainly, but also often Bo or Mo) as well as in detergents (Ca) and can often be an excellent choice for small engines.
I want to gently push back on this statement. Energy conserving starburst does not come from friction modifiers but from the viscosity and characteristics of the base oil. I am not aware of additives and have never seen any show up in any VOA to specifically enhancing wet clutch drivetrains. I am aware that there are friction modifiers are used to bring ATF fluids to manufacturer specs and these modifiers are available. e.G. friction modifiers to make certain Dexron or Mercon oils suitable to use in Chrysler transmissions. Otherwise, you get converter clutch shudder on lock up.The friction modifiers being referred to here are the ones that are required to get the "energy conserving" starburst. The same ones that hurt wet clutch performance. These oil listed above are surely JASO MA certified for wet clutch performance. Small engines dont need energy conserving oil, they dont need to retain wet clutch performance.
FarmForce is correct that motorcycle oils contain more ZDDP which certainly isn't a bad thing for small engines with plain bearings and flat tappets
I don't think so ... Redline has up to 2200 ppm 1800 ppm was standard in SJ oils, then was subsequently reduced to around 800 ppm in current SN oilsIs this oil too zinc heavy for my Kohler 27hp Efi ?
https://www.penriteoil.com.au/assets/pdf/catalogue/motorcycle.pdf
I have the 5w40 in the shed
Well you go ahead and use it then and I'll continue using an automotive oil lawnmowerQuite the opposite is actually the case! Motorcycle oil is usually much higher in ZDDP (Zn and P mainly, but also often Bo or Mo) as well as in detergents (Ca) and can often be an excellent choice for small engines.
THAT!Motorcycle oil is not the same as car oil....it lacks friction modifiers
I've used MC oils in my ope in the past, worked fine.Quite the opposite is actually the case! Motorcycle oil is usually much higher in ZDDP (Zn and P mainly, but also often Bo or Mo) as well as in detergents (Ca) and can often be an excellent choice for small engines.
