Just curious if using a slightly thinner oil (sacrificing some OP), would result in the water temperature of the coolant to fall slightly due to the fact the thinner oil will be absorbing more heat.
If too thicker oil is used, increased friction/heat build up, is then heat transferred to the water coolant and show up on the temp gauge of the radiator?
Or would the oil get hot instead?
Not sure if I've made myself clear.
