Hey guys! I've been browsing BITOG for a few weeks now, and have finally joined. I'm enjoying all I'm learning.
I take care of a few cars that use the Motorcraft FL400s filter. For Fram filters, this is #3600. I can't remember the Bosch or Purolator numbers. Anyways, I am wanting to go to an extended drain with full synthetic oils on a few cars that belong to family members a few hundred miles away from me. I don't get to see these cars as regularly and would just like every margin of extra protection in case I can't get to them at exactly 7500 miles, or whatever interval I choose as prudent. (Don't want to argue OCIs in this thread, just get filter info, thanks!
I like the idea of having a lot more filter media for longer life, as well as expanded oil capacity. What I'm trying to figure out is if it's OK to go from the FL400S to the FL1A filter size. The mating surfaces are very similar (gasket diameter) with the FL1A being ever-so slightly larger than the FL400S. The threading appears identical. I don't know about bypass PSI levels though.
Do any of you guys have experience with this particular situation? I will probably be using the Bosch or PureOne equivalents of tehse filters, but I don't have those part numbers memorized.
Also, does anyone know of an oversize filter for the Motorcraft FL2021?
Thanks in advance!
Thanks in advance!
