Thinking of getting an electric lawn mower
Michigan
I have about a 1/4 acre lot. I currently use an old Craftsman self propelled mower. It runs good but is pretty beat up. I was thinking of getting a new mower and going electric.
Anyone have experience with electric mowers?
Get a Honda gasoline lawn mower without a blade clutch (I believe that's what it's called). Mine's 15 years old, I run it hard, and it still runs like new. I changed the oil maybe 5 times in it (doesn't burn any) and the air filter maybe twice. Other than that, nothing.
IMHO Honda makes better lawn mowers than cars.
We have a Makita that uses two 18v Li-ion batteries. Does a nice job cutting, runs about 45 minutes on a pair of batteries but it's sold with 4 and a charger. I've got dozens of tools that use the same 18v li-ion batteries. It's a great mower. If you already have the Makita battery system - then this is a great choice.
EGO is based in Grand Rapids, MI if that matters to the OP. My workplace has one and it works o.k., maybe better than o.k.. All plastic, this old geezer thought it would break easy, but it has held up well. It will mow about 30 to 40 minutes on one 56v, 7.5 amphour battery charge. Ours is a mulching mower. I don't know how it would work on 2 week old spring turf that was missed while on vacation. Otherwise, I admit that I am pleasantly surprised by it's decent performance.
EDIT: The Grand Rapids, MI appears wrong. I don't know if they moved, or there used to be a Grand Rapids presence that changed. or what? Maybe customer service in MI: ?
EGO Customer Service
120 Ionia Ave SW
Grand Rapids, MI 49503-4195
1/4 acre with common big box type electric mower is pushing it. Maybe okay if you work fast, but the charge will be low when done. And not sure what would happen after the battery ages a few years.
After I wear out the gas powered Honda mowers I own I am going battery.
One plain push mower is 15 years old still runs like new - the other 10 year old self propelled still runs like new.
I use the self propelled 9 out of 10 - if the engine stops working I would put the older engine on it.
I am 66 - so good chance I will get lucky and die before I need to go electric. :unsure:
I am not anti battery mowers -
On my bucket list is to have a lawn large enough I could justify a zero turn mower
And pretty soon you can choose between a gas or battery version.
I have about 3 acres that I mow. I use a 21-inch self-propelled Greenworks for the cleanup and on slopes that make me nervous on my Rider. It's an 80-volt brushless; it eats up anything a gas mower can cut, and it handles some steep grades. It came with a 2.0 ah and a 4.0 ah battery. The 4.0 runs for about 45 minutes, but again, on some steep grades. It's reliable, lightweight and versatile. I liked it so much I bought an 80-volt leaf blower, string trimmer and chainsaw to run off the battery set, which is now 5 years old.
Still on my first mower, corded electric. Ans a neighbour donated an almost newstihl corded electric when he moved out. Otherwise I'd have been looking at a battery electric mower.
Can't beat the low maintenance of an electric mower.
What really makes the difference is if you can work on small engines. Battery aging is a factor and the rare spontaneous combusting unit is always a concern in the back of my mind.
Buddy of mines Dewalt battery blew up within the past year and almost burned his house down.
I think this is the key with these things. Having multiple batteries that interchange with other tools. And the batteries themselves being somewhat affordable. Many of these mowers run off large, expensive batteries that are cost prohibitive to replace.
Most won't run for as long as advertised, especially in high, heavy grass. But if you have several tools that can interchange, or if it is sold with an extra set, it won't matter. Slap in another set and finish the job.
Some of these units like the EGO system have large, expensive batteries that can cost over 70% as much as the mower itself to replace. Making it an all but disposable item when the battery goes south.
https://www.acehardware.com/departm...h-mowers/F013938?variationProductCode=7013945
https://www.acehardware.com/departm...cessories/cordless-tool-battery-packs/7013943
My neighbors ego electric caught fire three years ago. His second ego won't mow his entire front and back before the battery dies after the third season. Much smaller lot than 1/4 acre. I don't know of any current electric push mowers that will cut that large of a lot on one charge.
My daughters Facebook MP used Honda died so I was going to buy a Skil elec lawnmower but I did some research and guy had his house burn down from a Skil battery spontaneously combust. He was warning people not to buy them. I/she ended buying the LAST gas Honda on display at Home Depot was going to sell (so lucky ) If I was going to buy ANY elec lawnmower I would only buy a Mikita/Milwaukee/Dewalt lawnmower as they have a fairly good 20 year track record of lithium battery design to not start fires. There must be some fires, those brands "LIVE batteries." I know they are expensive, but so is your house. Unless we can go back to gas engines again after the stupid laws to ban gas mowers can be crushed. And myself, no, I would not trust GreenWorks batteries.
