Thicker vs Thin (fuel efficient) ATF for older vehicles
I feel like this is a topic that isn't talked about enough. Sorry for the long read but I wanted to share my experience with this.
I have a 2006 Infiniti G35x 5AT and I've tried a decent amount of fluids over the years in this car. With other cars too. The car was originally spec'd Nissan Matic J ATF and that was mostly discontinued and superseded by Nissan Matic S. Which is backwards compatible with most Nissan/Infiniti transmissions that originally spec'd Matic J/D/K. Nissan Matic S is a "fuel efficient" ATF that is formulated for modern transmissions like 6/7 speed autos etc.. Eventually at 108k miles I ran into the dreaded P1757 code where the Valve Body needs replacing. The car has been driven hard at times as any sports car should be driven. I also put 60k miles on it doordashing when it paid a lot during the pandemic, so I'm sure that didn't help. I bought a used transmission for $300 and took the valve body out of it. And is working great with no needed programming. Since the failure I've tried finding the best transmission fluid for each car I drive. It's been very interesting seeing how different ATFs can affect the driving experience so much. I have found that in cars where they originally spec the older style thicker fluids—that works much better than the new fuel efficient stuff. After the Valve Body repair I used Valvoline Maxlife which worked okay but I felt like it could shift a little better. It was missing that silky smooth feel, mostly at low speed shifts. Then I did 3 drain and fills with Valvoline Import Multi Vehicle and it literally feels like a new/rebuilt transmission. So smooth and feels how the car did when I originally bought it at 54k miles when it had the original Nissan Matic J (thicker fluid). This same experience also applied to my 2003 Toyota Avalon I used to own. Valvoline Maxlife while acceptable felt like it was lacking at times. I changed the fluid to Valvoline Import and again, it felt like a brand new transmission. Import ATF met the original Toyota T-IV spec for the Avalon where Maxlife was for cars that called for Toyota WS. Before I serviced the Avalon transmission the fluid was completely dark brown and stunk at 180k miles and hadn't been changed since 30k. Oddly enough no metal was present on the pan magnets.
Im wondering what your guy's experience is with Valvoline Import Multi Vehicle ATF. I think it's a very underrated fluid for older cars that originally spec'd non fuel efficient ATF. I'm surprised it's not talked about more. Most people just talk about Valvoline Maxlife, which is a great fluid too. I'm still interested to try Amsoil Signature Series ATF too as I've heard that's the best transmission fluid.
Some stats about viscosities (at 100°c)
-Valvoline Import: 6.9cst
-Valvoline Maxlife: 5.9cst
-Nissan Matic J: about 7.5cst
-Nissan Matic S: 5.9cst
Import multi vehicle is an older style higher viscosity fluid with the additive pack centered more towards older transmissions. I'd also recommend Castrol green bottle high mileage which i know home depot and amazon sell.
My 4 speeds love it the most but it is thicker at 8 cst and it's designed for the old 4 and 5 speeds of the time. Not a long drain interval atf but I spill and fill every 10-15k. Have 297k and 344k on my since new 4 speeds no rebuild.
In previous threads discussing toyota ws the thin FE variant has a tendency to cause elevated wear leading to more valve body failures in the US but outside of the US where they don't get filled with it but the thicker non FE variant that is also WS they don't have the issues. It's why i think the 10 speed has valve body wear issues. That 4.5 cst atf is already thin and when it roasts when towing or the hotter running diesels it gets even thinner. My 10 speed runs cool at under 170f so i'm not too uncomfortable running it.
https://msdspds.castrol.com/bpglis/...EAF92768025805600724B2B/$File/BPXE-AFE8TS.pdf
Wow that's a lot of miles on an original transmission but very doable with the right care. How do you think Valvoline Import would hold up over a 30k interval? They do list it as a full synthetic but I'm sure it's not 100% synthetic. Also have you noticed any decline in shift quality towards the end of your intervals?
It's group 3 but more shear stable. It should be able to do 30k unless it roasts. Do another drain and fill at 20k and see how it looks. The older fluids were not for long drains it was common to have 12k intervals back then with those fluids and if you did you had no problems.
