Thicker gear oil in Transfer case to stop leak?
I have a 2004 Lexus RX330 and the transfer case has developed a leak. About every 5,000 mi. I have to top it off with a half a quart. The car is just a beater, it's something that runs good but it's 20 years old If you get my drift. Now normally I would fix something like this but it's calling for 18 hours labor time because everything has to get dropped just to get to it. So can I use 75 w140 in the transfer case instead of the 80w90? Or does anybody know any decent stop leaks? I thought about the at205 but I don't know if I'm comfortable with dumping a stock leak in. I thought maybe thicker gear oil would be better?
I'm being told that it's the differential cover which you have to drop everything just to get to. It's like 18 labor hours on Moto logic
I had a transfer case leak in my 2005 RAV4. Took it to a transmission place and the guy told me it would cost $750 to remove and see what was wrong and the price would go up from there depending on what the problem was. I said thanks but no. He said ok, topped it up and charged me $20. That was about 240,000 miles. I continued to top it up every 5000 to 8000 miles until the transmission blew up at 400,000 miles. The transfer case in the RAV4 only held about half a quart so I'd check your capacity and top it off so that it doesn't go below half the capacity at worst. I got pretty good at topping it off. It's not that easy. I had to string together all of my socket extensions to get the proper clearance to turn the fill bolt.
That's what I might do. It holds a quart and it looks like about every 4, 000-5000 mi. It's about half a quart low so I guess what I'll do is just top it off every 2,000 mi which is a pain in the butt but it's just a work car. $2,500 to fix it just doesn't make sense on a car that's worth five grand at most. I've been looking at the AT205 as well.
A repair that is probably 4x what the car is worth is not a good investment, obviously.
You can certainly try a thicker lube, but that is unlikely to stop any leaks. Once the lube warms up to full temp, it's not THAT much thicker over the alternative, to a point where it won't leak at all. It's just going to leak slower.
You could try Blue Devil stop leak, they make one that specs diff on the back label. I used it and it worked pretty well a couple times but if you are saying cover, it may not work. Worth a $10 gamble, I would try the 75w140 as well.
