Ok, here is a little background of the vehicle as far as maintenance since I've owned it. Purchased the 2003 Matrix back in 2006 and maintenance was pretty much oil changes every 5-10k on dino oil. All other fluids were from the factory fill until September 2014. The car had 170k miles back then and at that time last year I replaced the coolant, brake fluid, MT fluid and power steering. All these fluids have been replaced at least 3 other times since then, except for the brake fluid, because of other work done on the car after the initial drain/flush/refill.
So, I came here to ask why the thermostat would rust at the top like this. I had a buddy convince me to buy a new thermostat and get the TRD 170F/76C type. I installed this on 1/19/2015 and just today decided to take it out and put a new OEM Tstat rated 180F/82C back in, after doing research and finding I should never have installed a lower rated Tstat in the first place. Anyway, there was no rust in the Tstat housing or inside the block where the Tstat sits, but why would a new Tstat, only 7 months old, do this when the coolant was new? By comparison the original 11 year old Tstat was not rusty when I replaced it with the TRD back in January. Luckily I'm not worried about the cooling system anymore and just wanted to share this experience and see if anyone else has had this happen.
