Car in my sig. Warms up plenty fast, but coolant temp seems to swing lower than it should when on the highway or with the AC fan running. Even on a hot day, my Scangauge reports coolant temps consistently around 82C / 180F when cruising, or if the AC fan is running. When AC fan isn't running in slow moving traffic the temp cycles normally between 96C/ 204F (radiator fan shuts off) and 103C / 217F (fan turns on).
Thermostat was replaced maybe 7 years ago with what should have been an OEM unit rated at 87C / 189F. System was flushed and filled with all new 50/50 mix as of a few weeks ago. Old coolant came out green with a little brown tint and a few little flakes came out with the flush, but otherwise system looks spotless inside.
I thought rated temps on a thermostat indicates when it begins to open, plus or minus a couple degrees, so it almost looks like either I have an 82C/ 180F thermostat installed by mistake, or the OEM thermostat is pretty far out of spec on the cool side.
Any thoughts on this? New thermostat is only $12 and super simple to access so I'm tempted to just replace it anyways.
