How cutting open the oil filter and taking a look inside.
You are attributing the fix to this problem was the dino oil. If the M1 did dislodge the crud it is in your oil filter and now that you changed it, you have solved your problem (temporarily). Also, you may have dislodged some crud from the oil pick-up screen when you drained your oil.
Put in some ARX.
Can you get some pix of your cut -up oil filter?
Put in some ARX.
