Originally Posted By: Hokiefyd
Originally Posted By: joel95ex
there is a recall on AT for accord just recently. may affect the acura too---was a bearing issue
I don't believe it included any Acuras, but it definitely included Accords. It was for CR-Vs, Accords, etc. Only for the 4-cylinder transmissions as I recall. If the driver repeatedly and quickly shifted from reverse to drive to reverse to drive, and kept doing that (like rocking the car from snow), it could wear one of the shaft bearings. So they adjusted the programming to soften the engagement between forward and reverse.
Lately, I think Honda is as guilty of programming errors as anything else with their transmissions. Service bulletins exist for a variety of Honda/Acura cars for torque converter shudder. Our MDX was doing this also. Seems their low-speed engagement for the torque converter may have been a little bit too aggressive, and the TSB included a re-flash to raise the engagement point. It fixes the problem, but it's something that should have been worked out better during development.
is the re-flash also affect later MDX? the TSX also share engine and transmission with Accord, so, is it affected too? thanks
