I have a Coleman generator with a Briggs & Stratton 10Hp OHV Gen Power 305. The info tags says: 5BSXS 3422HT. The owner’s manual is for models 110000,120000,200000 and 210000. I don’t know the exact model and can’t find anything on the B&S website using 5BSXS 3422HT.
The problem is it won’t start (no spark). The engine has an oil level sensor system that is wired into the On/Off switch which prevents it from running with low oil. I have checked the oil level and it is fine. For troubleshooting purposes I would like to disable the On/Off switch and oil sensor to see if it is that or the ignition. I know the switch and sensor grounds the ignition but am confused on how the On/Off switch is wired. On the back of the switch are three terminals. The middle one goes into the engine front cover, I assume it goes to the ignition. The Off side goes to the oil level system (from the switch the wire runs to a small electrical cube from the cube a wire runs to a oil level sensor in the engine). The On side of the switch runs to ground. This seems a little backwards to me.
I disconnected the middle wire from the switch thinking that it would take the ignition out of the switch but still no spark. I have not been able to find any info on this set up nor any wiring diagrams or troubleshooting tips. Anyone have experience with this or know of a website, etc.. that would help.
A little background: I bought the generator 3 years ago. I start it about 4 times a year and let it run for about an hour. It has always started on the second pull and has always run smooth.
Thanks
jack
Thanks
jack
