Truck has 22.5k going on 3rd fluid and filter change. While the fluid looked clean each time while draining out of pan the bottom had quite of bit silverish tint with quite a bit of debris on magnets. Also noticed at times the downshift between 3rd and 2nd would be harsh.
Switched over to the Royal Purple Max ATF and noticed a dramatic improvement on shifting performance and 10 to 15 degrees cooler temps across the oil temp, coolant and transmission. No way I'd ever go back to that subpar overpriced brown green looking junk.
Many people hate Royal Purple but it's folks who have never used it or know the first thing about cars. I've gone to the Synchromax in the transfer case and its never shifted in 4WD easier and been quieter as well.
Run RP in everything except the crappy tree hugger electric power steering and the coolant.
