Well, it's tritium, so the same as it's handled anywhere else. Generally, you try to avoid having the tritiated water released in the environment, but tritium is produced naturally and is in all water so a lot of these "concerns" , absent of actual concentration figures, are over the top or even fear mongering. The limit on tritium concentration in water varies on a per-country basis, but it's generally viewed as benign at typical (low) concentration levels. You can tell the Guardian didn't do any sort of investigation into tritium, given that none of that is mentioned in the article.
Up here, the operator would have notified the CNSC immediately if we had a leak (which has happened, but they typically aren't outside the plant unless somebody buggers something up, like the wrong tank gets emptied) and the CSNC would have put out a notice, and then how the media runs with it will vary wildly depending on their bias.
The NRC has a page on tritium here:
https://www.nrc.gov/reading-rm/doc-collections/fact-sheets/tritium-radiation-fs.html
You can compare that to the CNSC page on tritium here:
https://nuclearsafety.gc.ca/eng/resources/fact-sheets/tritium.cfm
