The Fram HP1 is NOT just a PH8A with a heavy case...
No problem, I'll leave the Frams for you!
Sure, they both work when things are normal. It's the margins for error that I think are important. If the filter starts to cave in just a little, then the bypass is no longer held against the top of the can. I know it's subjective, but I applied slightly more hand pressure than you'd need to collapse an empty soda can. And that centertube is really scary; it buckles with the greatest of ease.
I understand that that Frams are not, apparently, failing "right and left." I just don't see any reason at all to buy one when you can get such obviously superior construction, for the same price, from a Champ Labs, Purolator, or Wix filter. If Fram offered these for $1.50 or so, I could see them as an option if I needed a real cheapy, but for between $5 and $10, I'm buying an M1 (CL made) or a Puro.
quote:
The great fram troll strikes again. LOL
MUHAHAHAHAHA!!!
I don't know, ekpolk, your hands look brutally strong... I think what you did to that filter element is far beyond the capability of the hands inside my engine...
Besides, you may not have known your own strength, due the the adrenalin rushing through your body after seeing those cardboard endcaps...
Yeah, when I cut a filter open and I see that cardboard, the rage begins to rise. My nostrils flare, I notice my complexion starting to take on a green hue, and my shirt starts to tighten. Next thing you know, I'm standing there with a torn shirt and a crushed filter element clutched in my fist. . .
That, believe it or not, is the element from the size of filter spec by Nissan/Infiniti for installation on the version of the VQ35DE V-6 used in the 350Z and G35! They don't call it the "thimble filter" for nothing, and I'm not kidding when I say you can put two of them (the whole filter) into a Coke can. . .
