The confusion around BMW M oils continues
Frisco, TX
Someone just pulled this off BMW ISTA database:
http://www.m3post.com/forums/showpost.php?p=15330450&postcount=1951
The chart shows that only Castrol Edge Professional TWS 10w60 is allowed in the S54, S62, S65, & S85 (M car) engines. This is contrary to what an August 2013 BMW bulletin said:
Originally Posted By: BMW Oil Supplier Listing Aug2013 V2
BMW CURRENT LISTING OF SYNTHETIC OILS (US Market)
Required maintenance work or services should be performed for your vehicle by your authorized
BMW center.
BMW High Performance Synthetic Oil is recommended for scheduled engine oil changes.
BMW Genuine Oil SAE 5w30 Synthetic Oil*
* Does not apply to M vehicles - see below for further information
BMW part number 07 51 0 017 866 – 12 x 1 qt case
BMW part number 07 510 038 678 – 24 x 1qt Enviropack
BMW part number 07 51 0 017 954 – 55 gallon drum
BMW recommends that you check your engine oil level whenever you add fuel to your vehicle.
If you need to add oil between oil changes and BMW High Performance Synthetic Oil is unavailable,visit your nearest authorized BMW Center. For information on checking your engine oil level refer to your vehicle’s Owner’s Manual.
The choice of the right SAE grade is based on the climatic conditions in the region in which you normally drive your BMW.
To best determine which SAE grade is best suited for your vehicle contact an authorized BMW center.
*The following is the only recommended and approved synthetic oil for BMW M (Motorsport) vehicles in the US market with gasoline engines, at the present time.
BMW Long-life rating LL-01 Synthetic Oils for BMW M vehicles
equipped with S54, S62, S65 or S85 engines
Castrol EDGE Professional TWS Motorsport SAE 10W-60 Synthetic Engine Oil, BMW part number 07 51 0 009 420
or
Castrol Edge Professional OE 5W30 Synthetic Engine Oil, BMW part number 07 51 0 037 195
The following is a listing of synthetic oils recommended and approved for use in the BMW B7 ALPINA in the US market:
(source: http://cache.bmwusa.com/Pdf_59436a7e-93e...72-e40e9ca36785)
Frankly I'm quite aggravated that BMW can't get their story straight on what oils are allowable in certain M engines. For many years they only allow the Castrol TWS, then release the above bulletin in August to expand it to any LL-01 oil, and now their own database shows that's not the case. I'm not sure if the ISTA database is just a few months behind on updates, or if they've reneged on the use of LL-01.
The newer M5 & M6 engines (twin-turbo V8, code S63B44Tu) do allow LL-01, for what it's worth. Many owners of M cars have since switched to oils like Mobil 1 0w40 and the cars seem to run quite well with them. I've seen a bunch of used oil analysis, and there are a lot of people posting that the oil temps are lower on the track and the car actually drives better.
Obviously this has been the topic of much discussion across the BMW owner websites, and this recent ISTA info only stirs the pot again.
Here's our own discussion of it from late last year:
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=3151053
Agreed but at least they're staying on top of the issue instead of letting something grow and fester. Or outright ignore similar to Toyota with the slugging problem. I own a Toyota so no smart remarks there guys.
My read is that the 10w-60 and Castrol EDGE 5w30 OE are the only oils recommended for the M engines. BMW genuine oil isn't suitable.
My read as posted/quoted was that only those two ll-01 oils are suitable. Thus it is consistent. Maybe I'm reading g the quoted text wrong, or sans some punctuation?
That's what I took away from it too
I actually read it differently: I read it that BMW High Performance Oil 5w30 is NOT LL-01 and therefore not suitable.
My read:
BMW Genuine Oil SAE 5w30 Synthetic Oil es no bueno por M.
Castrol EDGE Professional TWS Motorsport SAE 10W-60 Synthetic Engine Oil y Castrol Edge Professional OE 5W30 Synthetic Engine Oil es muy bueno por M.
The linked BMW document is not formatted or written all that well. When it says "BMW Long-life rating LL-01 Synthetic Oils for BMW M vehicles equipped with S54, S62, S65 or S85 engines", that reads to me that the two oils listed immediately thereafter are the only LL-01 synthetics that are recommended for M vehicles. It does not preclude any other oils in the document from being LL-01, just that there are no other LL-01 oil that are appropriate for the listed M engines.
Originally Posted By: NMBurb02
My read:
This is exactly how I read it too. For example, Mobil 1 0w-40, even though LL-01 approved, is not suitable for those M-series motors.
Scott
My read:
Scott
Except that there is no such thing as "LL-01 approved for M vehicles". In fact, Castrol Edge Professional TWS 10w60 isn't even LL-01. It just reads "exclusive approval for BMW M-models":
ACEA A3/B3, A3/B4
API SN/CF
VW 501 01 / 505 00
Exclusive Approval For BMW M-Models
Dan,
After senorfunkypants @ m3post.com won't let the issue go to rest, I re-read the bulletin, and it does say the oil has to be LL-01 and "approved for M" or it does not go into our M3s.
Looks like the only oil approved for our high revving S65 is the Edge Pro 10W60. Does this mean I will drain the Mobil 1 0W40 I'm currently running? Heck no...my car runs great with Mobil 1/LM MoS2.
Maybe TWS omitted LL-01 labeling all together because no standard series BMWs will ever need that oil, just deducing here.
The hard fact is that 0W40 has reduced the wear of bearings as witnessed by the few used oil analysis we've both seen on m3post.com.
Castrol wouldn't bother paying for TWS to get certified as LL-01 since it was never intended for widespread use. It would easily pass, in my opinion.
Someone just clarified something for me: the bulletin I linked to that mentions LL-01 was released by BMW USA. The ISTA database is a global thing...so clearly BMW has a different recommendation here, for some reason. I suspect it may be related to bearing failures.
According to the owner's manual, my V8 twin turbo powered M6 is okay with LL-01 in 0w30 or 0W-40.
From the manual....
When selecting an engine oil, ensure that
the engine oil belongs to the viscosity grade
SAE 0w30 or SAE 0W-40
ACEA A3/B4
API SK/CF or superior grade specification
Now the specialized TWS is applicable to my 3 liter inline 6 cylinder Z4M and other earlier M3, M5, and M6's. Legend has it that early production versions of the 3 liter M engines were failing catastrophically (and expensively). BMW used their ultimate lube to address these problems. The 2008 I own seems to work well with TWS.
The only problem with TWS is its $14.50 a quart price.
If only Advance Auto would stock it and include it in their $29.95 oil change deals.
Crazy as it sounds, that's a good deal.
It would be great if Shell would bring Helix 10W-60 to the US in their Pennzoil Ultra Euro line up.
But that would be very unlikely.
Originally Posted By: bigjl
I'm with Overkill and NMBurb on this.
M engines have a choice of the two oils listed. Not any LL01 oil
Castrol's Belgian 0W-40, GC (now Belgian too), and Mobil 1 0W-40 are fine for the 4.4 liter M engine in the 2012 to current M5 and M6 models.
At first I interpreted the bulletin to mean that any LL-01 oil was approved for the S65 engine. Now after studying it some more I am not so sure.
I was planning on making the switch to Mobil 1 0w40 next oil change but Im second guessing that. I wish BMW would provide some clarity
it is a simple choice. run the oil you know is approved, and IF you have an engine issue/warranty is good.
oh.... and get the extended warranty!
