A hydrometer will indicate state of charge, not state of health, or percentage of original capacity remaining.
I've had large batteries read 1.275+ on all cells and maintain 12.75 days off the charger, but would fall to 11 volts charging a cell phone.
GC-2s are not known for their ability to provide high amperages for high durations. They do not have a CCA figure, just like engine startig batteries rarely have am amp hour capacity figure
GC-2 batteries are all about deep cycle duty, and accumulating lots of deep cycles before failure, assuming they are returned to a true full charge regularly.
The Hydrometer is a great and irreplaceable tool in determining if one's charging source is capable of meeting this ideal.
Most would find their charging source lacking, if they bothered.
The thicker denser plates of GC-2 batteries, makes them more tolerant of forced overcharging.
Look into an Equalization charge. After a normal 'full charge' Apply ~5 amps per 100Ah of battery capacity until terminal voltage rises as high as 16.2 volts for as long as it takes specific gravity to stop rising. The electrolyte will warm up, and can appear to no longer be rising, until one accounts for the warmer electrolyte.
OTC4619
had a built in thermometer which says how much to add or subtract to the float's reading.
Give it a few seconds to absorb the heat of the electrolyte. Make sure no bubbles stick to the float.
I use a Meanwell rsp-500-15 for all charging. Manual charging, as automatic stops short of ideal.
It is a 40 amp adjustable voltage power supply capable of outputting 40 amps to maintain any chosen voltage, from 13.12 to 19.23 volts.
I've a digital ammeter on the output, and a 10 turn voltage dial
For a pair of GC-2's @ ~220 amp hours, you'd want a power supply capable of no less than 12 amps in order to bring them upto 16.2 v and perform the capacity restoring equalization charge.
Flooded group 31 batteries are a bit starved in the electrolyte department.
Marine 27/29 and 31's often need ridiculous times held at high absorption voltages in order for specific gravity to max out, and if perfectly recharged will daccumulate about 5 to 600 deep cycles to 50% SOC before capacity loss becomes too obvious to continue in deep cycle duty, and they take forever to reach full charge.
GC-2s , a true deep cycle battery will do 1200 to 1500 deep cycles if perfectly and promptly recharged to full. They often need less time to get from 95% to 100%, compared to flooded marine 24/27/29/31
Batteries designed for engine starting will last about 50 to 100 deep cycles, if promptly and fully recharged, after an unintentional deep cycle.
But there are tons of influencing variables such as age and manufacturer and depth of discharge and temperature and.......
Here are the guts of a 12v group 24 marine battery, compared to a 6v GC-2 battery:
source:
Light Cycle vs. Deeper Cycle NOTE: This article deals with FLOODED marine batteries, not AGM or GEL batteries. The Problem: The problem, as I see it, is one of dishonest marketing where multiple battery types wear the same clothes (sticker) and will perform differently when
marinehowto.com
Recovering capacity on sulfated GC-2's is likely, with an EQ charge, as long as they have not sat 100% discharged for months on end.
The tools required to perform a proper 15.5v to 16.2v EQ charge, will allow one to get better lifespans from subsequent Lead acid battery banks, and perhaps also be able to charge Lifepo4's, depending on the BMS.
