Temp gauge
gj
Pulaski VA USA
I have a 1995 F-150.The temp gauge has stopped working.The heat is hot so thermostat is ok.What do I need to look at to get it going?Thanks
First thing to check is the sending unit. That is most likely.
A good manual or online charts will tell you the values cold, warm, and hot.
Check the voltage or resistance with a multimeter.
But maybe a connection , wiring, or dash gauge is bad.
The sending unit is not that much $, so maybe you can just throw that part in and take your best shot right away, if you are uncomfortable with testing it.
