all made by premium guard^ they’re the best value in filtration right now with excellent efficiency to boot. i run them 12k miles in industrial fleet service.Carquest Premium 99.5%@20
Microgard Select 99%@25
Premium Guard EX 98.7%@15
Premium guards I've been using, lately they seem to be the best quality. And the new m1s at WalmartCarquest Premium 99.5%@20
Unfortunately, ISO efficiency data is severely lacking from the oil filter brands. You will get responses but there's little data to back it up. Anyways, Just use any of the brands mentioned & it'll be just fine for your 5k intervals. I like Purolator filters & they were one of the only ones providing data. If you let us know your Purolator part number, efficiency data may already be listed here already.Looking for your opinions of the top 3 best oil filters. I only run 5,000 mile oci's with Syn oil so dirt holding ability is a concern. Just looking for great filtering efficiency.
So you didn’t even answer question. Thanks for adding nothing.Dirt capacity is almost irrelevant, when I cut open oil filters at 200hrs or 6,000 miles they're still fairly clean.
For $13 I don't think anything beats fram synthetic endurance oil filters.
I can get down to a 2 micron "hydraulic filter" but they run around $40 or more, may not have a bypass, or be available in the thread size you're looking for, ect.
All those are trash compared to a 2 micron wix hydraulic filter if the question is efficiency.So you didn’t even answer question. Thanks for adding nothing.
Anyways my 3 are CQ premiums, PEntius PXL AND DONALDSON white can
Hydraulic oil filters don’t fit on an engine and I wouldn’t want to use one unless specs and bypass matched say a Donaldson filter.All those are trash compared to a 2 micron wix hydraulic filter if the question is efficiency.
It kinda boils down to how much is someone willing to spend and how hard are they going to look for it.
If you’ve got a Rural King anywhere near, the new M1’s are a bit cheaper there.Premium guards I've been using, lately they seem to be the best quality. And the new m1s at Walmart
What do you mean hydraulic filters don't fit on an engine?Hydraulic oil filters don’t fit on an engine and I wouldn’t want to use one unless specs and bypass matched say a Donaldson filter.
Seems like there has been a change of mind about Fram and ISO 4548-12 since the "goodtimes" days.I would say Fram has been the leader in aftermarket efficiency, showing the numbers and have researched, tested, and developed media. They have shown their test lab in videos, and list several filter numbers tested. You want manufacturer specs met.
Would you include the STP XL in this group?Carquest Premium 99.5%@20
All the same filter with superior build quality currently.
Yes. But in some areas they are Champ made so inspect before purchase.Would you include the STP XL in this group?
No but several filters will match them at 20 microns and for less than half the cost.Dirt capacity is almost irrelevant, when I cut open oil filters at 200hrs or 6,000 miles they're still fairly clean.
