Hello all my internet friends!
I've been resurecting an old 5hp snowblower recently and have actually used it a couple of times this week. After fixing all of the rusted parts and putting a new axle and wheels on it, a new carb had it running great.
One problem has cropped up yesterday. The governor has decided to stop working. I was half way through the driveway when I noticed that under load the engine would not pick up revs and the snow would dribble out of the chute and eventually clog if I didn't stop moving forward and let it catch up. I pulled the heater box and verified that at idle the governor lever was moving a bit to keep a steady idle but would stop moving when I'd engage the drive and when it loaded up with snow.
I found it odd that it worked just fine for 20 minutes before and just stopped. I checked the linkage and all was normal with the spring hooked up. I could also maunally operate the governor and it would throw snow just fine.
For the L-head experts: Does the governor inside the engine just get bound up all of a sudden and stop working? Would a stronger spring help me out at all? Is the governor in the oil bath and will the wrong oil cause it not to work right? I've done a couple of oil changes on it since it sat for so long and I'm using NextGen MaxLife 10w30 because it was cheap at Autozone.
It seems that when it's not running the spring pulls the governor arm towards the carb and that opens the butterfly wide open. When it starts up, the governor kicks in and the governor arm goes all the way to the front of the machine and closes the butterfly. This is why I thought that a stronger/shorter spring would possibly help. There are also other holes on the governor arm above and below where the spring is now attached. The governor arm is vertical with the pivot point at the bottom. The spring is in the middle of the arm, so should I move it up or down?
Thanks for any advice or help that you can provide.
