Tecumseh Carb Rebuild..
MIchigan
Rebuilding a carb on a Craftsman snowblower with a Tecumseh carb. And when I removed the float a spring fell out that was between the float pin. Question is.... how is the spring oriented during installation. It has a long tail on one side and a shorter tail on the other?
Helpful hint:
If this is one that has a rubber float needle seat.
I have found the easiest way to replace them is to blow them out using compressed air. Place your blow gun tip on the fuel hose inlet nipple. Usually a quick shot of air will blow them out.
Put a couple drops of oil on the new one and a small piece of metal rod or the blunt end of the appropriate size drill bit will be a good tool to push it back into its home.
Thanks Guys...I installed the carb...although the spring isn't functioning the way it's supposed to...it ran fine. First time I've seen one like that.
