Welcome new member!
I commend you an being able to clearly define your condition and limits. That's refreshing, to say the least! The fact that you can do this in your first post is that much more amazing!
As you seem to recognize, there is not a one-size-fits-all answer. What is more appropriate is to define your desired maintenance plan, and then pick products that support and compliment that plan.
Since you have a 2005 truck, it's likley your warranty has expired on the engine. So the topic of warranty is moot; anything that goes wrong is on your bill, and so appeasing the warranty conditions for an annual OCI really isn't requried any longer. That being the case, you could greatly extend your OCI to perhaps 2 or 3 or 4 years, use UOAs for validation, and consider using synthetics.
If you want to OCI anually, I'd just do dino, and probably not even use the BP filter, and limit my OCI's to 6k miles; making two per year. In fact, using a quality oil and a quality full-flow filter might just get you to 10k+ miles on dino! It's been done with some frequency in Dmax engines, and ISBs that are well cared for can get there at times as well. I would caution you to use UOAs as verification a few times before you blindly go that far on dino. It can be done, but it needs to be done with caution.
It all comes down to a few things:
1) maintaining a level of safe, effective lube condition
2) seeking the lowest cost OCI
3) keeping the maintenance task as easy as practical
As long as you keep the oil healthy, it's likely the engine will stay healthy. This can be accomplished by either "super filtering" (bypass filters) or frequent oil changes. There are, by now, bazillions of UOAs that support this concept. The bottom line is to keep contamination under control. You can either filter it out, or flush it out; they achieve the same result.
So, with that in mind, you now come down to cost. If you're driving 40k mile a year, and downtime is costly to your operation, then synthetics and bypass make sense, because you can greatly extend the OCI and get good ROI. If the oil/filters cost 4x more money, and you can get 4x more duration out of your OCI, then you've kept the costs equal, and saved downtime, thereby making the maintenance tasks easier. Or, if you drive 15k miles a year or less, you can save a lot of money by having to do only one or two dino OCIs with a "normal" full flow filter, and nothing else.
I cannot recall how much oil an ISB holds, but let's use my Dmax as an example:
First, I'm still under warranty, so I must do at least one annual OCI, even though I run about 7k miles a year. I will not compromise my warranty by choice, so I must OCI. My truck takes 10 qrts oil and a "normal" Wix/NG filter. That will run me around $25 per OCI. How so cheap? Because I shop BOGOF sales, and they are out there, if you shop in advance. I'm not brand loyal; I use any quality brand name I can find on sale. I got Delvac 1300 last year for $6.50/gallon! Add in a filter sourced from Napa during their annual 40% off filter sale at $7, and I'm in for an inexpensive OCI that can last me up to 10k miles. Or, I could use synthetics and bypass filters, run my cost up to around $100 for that same Which makes more sense? As long as my UOAs show that the oil and engine conditions are safe, the clear winner in my use is the dino/normal filter. Why spend 3x or 4x more money for the same results? (note: the range of 3x to 4x acknowledges that some folks like me can and do find good sales. If you're not inclined to do as such, the savings may not be as great. However, I try to be fair; what I am comparing is cost to cost. You can find both dino and synthetic on sale, or at retail price. But the RATIO is typically about 3x to 4x, product dependent.)
Synthetics and bypass filtration are fiscal tools to extend the OCI, thereby increasing your ROI. To make them viable and pay off, you must extend the OCI out far enough to equal or surpass the investment. Period.
I'm not saying one way is "best" for all situations; I'm saying that you need to define you prescribed plan, pick your products that compliment that plan, and stick to it. You're already well on your way with that understanding. Now, sit down, pick the plan, do the math, and commit! If it is your intention to OCI anually, and you're less than 15k miles, I suspect you'll find that one or two dino runs will suffice very nicely, and make for easy, simple maintenance, and your ISB will still last forever.
And again, welcome!
