Synthetic Blends
Canada
What is the typical ratio of synthetic to conventional in a blend?
I see on the Wallyworld website, that a 5 quart bottle Valvoline Maxlife HM is only $0.80 more than VWB. You'd think the price would be somewhere between VWB ($16) and the synthetic which is about $25.00
Pennzoil Synthetic Blend has at least 50% synthetic. It is the only Blend i know of that actually has this information on the label.
Yep trade secrets except for the Pennzoil which uses it as a marketing tool. Wemay you gonna do a UOA when you run it? I'd like to see one as far as I know it's still a mystery add pack wise, would really rock if it's the same add pack as PYB with a 50% syn base.
Motorcraft is thought to be around 60% but otherwise it's pretty much a guessing game.
if they cost more nobody will buy them because its mostly about marketing oil is oil when it comes down to it ..........if one oil was better than all the rest they would sdvertise they are the best...
Absolutely!
Originally Posted By: BlueBird
I called Valvoline to answer that very question a few weeks ago , the tech told me Maxlife 5w30 and Durablend 5w30 are 25% synthetic
25% isn't too bad ... I thought it might be a lot less considering the modest increase in price over VWB.
Funny how both Maxlife and Durablend are the same percentage and they're marketed as different products
Keep in mind that there are different quality Group III "synthetic" base oils as well as different quality Group I & II conventional base oils. With a blend we don't know whether the lowest possible quality conventional oil plus just enough cheap Group III was used to just bring it into SN & GF-5 spec, or if top quality ingredients were used to produce a superior product.
Go by the experience you and others have with a product, not by the hype on the label.
That is true, I hadn't considered that
They *are* different products, though. Maxlife has extra additives for seal conditiong that are useful in a high mileage car.
Just like the full synthetic version of Maxlife is not the same as Synpower.
Also, aren't even most "conventional" oils synthetic blends now?
MC is said to be 60% syn
We should start a list!
MC 60%
Pennzoil Dexos 50% (Pennzoil Gold is probably the same thing)
Maxlife 25%
Durablend 25%
I think Valvoline probably has the most 'comprehensive' line-up of oils. I can't think of any other brand that has so many different options - it's almost confusing
Too bad many of their offerings aren't readily seen on the shelves. I've never seen the Dura Blend, Maxlife Syn, NextGen Maxlife Syn online or in store at places like Walmart and Kmart.
I second the list idea!
The Walmart in my area has
SynPower
MaxLife Full Synthetic
MaxLife Synthetic Blend
NextGen Conventional
They don't have NextGen Full Synthetic.
Originally Posted By: stchman
From what I see of oils on the shelf, synthetic blends are not that much cheaper than full synthetics, so why bother?
WALMART near me:
Pennzoil blend $17
Pennzoil Plat $25
QSUD $23
I can get a quality filter for the difference. Worth it to me since at a 5k mile oci (maximum allowed by Hyundai), i won't extract the extended oci benefits of a full syn.
