syn switch NOW LEAKS AND BURNS ????
md
173000 on a mountaineer 5.0. 4 months and 4000 miles and I only drained out 3.5 quarts out of 5.5 and now have a rear main oil seal leak. truck has had motorcraft 5-30 blend its whole life and I changed only to even up both cars. Should I drain it and go to a Pennzoil high mileage or go back to the motorcraft? but could the damage have already been done?
Well nothing (except repair) is going to fix the leak if it is truly a rear main seal leak. Yes you can switch to a High Mileage oil and it may slow it some. Yours does not sound to be terrible so I would go ahead and use the High Mileage oil of your choice.
So you switched to synthetic and when it was time to change the synthetic oil out you THEN noticed you were 2 quarts low and it was leaking?
What synthetic did you switch to?
Nothing is likely to repair a RMS leak, even though some claim ATP-205 will fix a slower leak. If it's already on the chopping block with 173k , might as well try it since a RMS leak can end the life of a low value vehicle, since the repair could cost too much.
It never hurts to go back to a thicker high mileage oil to slow the leak if your trying to buy time. 10w40 high mileage could slow it some.
I hope your going to check the oil level more often than between changes now.
Make sure its not the lower intake seal at the back of the block dripping down inside the bell.
Otherwise, change the RMS. It isn't a huge deal.
Originally Posted By: Ram01
Some motors works better with a blend or dino
It's a 5.0L Ford, it'll work fine on pretty much anything. And that statement makes zero sense.
Some engines may call for a synthetic, most non-Euro engines will be fine on dino of the right grade changed at a sane interval. But how they "work" isn't dictated by the type of oil that is in them.
Damage is done but go back to motorcraft leave syn alone
No damage is done.
Most people assume that it is a myth, but some times switching to a synthetic will cause a temporary leak. Don't worry about it and keep the oil topped up. After an OCI or two of synthetic oil, the leak will stop.
this all happened with the fill of pp. the truck never had oil leaks or burned this much oil. weird I am going to back to the motorcraft
No damage is done.
Yup, or will clean up some varnish that exposes an existing leak.
If your not going to repair the leak, might as well go with a 5w30 high mileage, M1 High Mileage if you want a synthetic, or any name brand HM conventional/blend, Pennzoil High Mileage is another good choice.
What damage?
Well I think the working theory is some crud was blocking a RMS leak and the synthetic knocked it loose and now it's leaking a quart every 2000. So the damage is that dissolved crud. I wish there was actually an oil that cleaned that well. I think it's probably a coincidence. I'm not sure what synthetic oil it was but I find it hard to believe a group 3 based oil would affect the seals any differently than any conventional.
I had a 2002 f150 I bought used that would smoke after using synthetic oil for 2 or 3 oil changes using Pennzoil Ultra/Mobil 1 High Mileage. It cleaned the deposits from around the valve seals causing oil to slip by and smoke on take off after idling for a min. I would periodically check under the valve cover for signs of clean up. It never smoked bad enough to bother me just a small poof and the engine was smoother and started easier than when I bought it.
Which synthetic oil did you switch to? I don't see that mentioned in the opening post. All I see is that the car has had Motorcraft 5w30 most of its life and then started leaking after being switched to an UNKNOWN synthetic.
Goes to prove what worked for 170000+ miles why change at that stage of engine life.
False seal or not, using my impeccable 20:20 hindsight rear view observer, even if the leak stops it was not worth it in this instance to changeover.
What damage?
Agreed, WHAT damage???????????
The 5.0 has a one piece RMS that responds nicely to a high mileage oil... Also as mentioned check the seal under the rear of intake, it's common to leak(shape distorts) and be mistaken for the rear seal... No, high mileage oil probably won't fix that...
Common scenario in high mileage engines suddenly switching to synthetic. Stick with the HM blends or use synthetic early on.
