Sylvania Zevo LED For Tail Light
Toronto, Canada
I installed them in Grote tail lights
https://www.grote.com/products/5370...optailturn-lamp-red-rh-w-license-window/
The existing incandescents were not bright enough and the Zevos were worse because there were no reflectors in the Grote lamps. Most of the output of the Zevos were lost because the leds face backwards. I lined the interior of the lamps with sticky aluminium foil tape and that made the lamps acceptably bright, as seen in the second picture.
The Zevos are bright, it is just that the light is emitted in a backward direction.
I could have used chrome paint instead of the aluminium foil. If I had to do it again I would just replace the entire lamp with this one
https://www.grote.com/products/53630-supernova-three-stud-led-stop-tail-turn-light-red-rh/
It has been a few months and the foil tape has held up so far.
Nice thinking on the foil, and its holding up well, good job!
I use the same bulbs in my taillights of my truck, they must have reflective material in them because they look great/brighter, Balrog006 is definitely right.
