- Joined
- Dec 7, 2008
- Messages
- 5,521
Last year I replaced both rear marker/brake light bulbs on my Impreza after about 12 years on the originals, which were also Sylvania branded but the build quality seemed different and apparently better than the two new 1157LL bulbs. Fast-forward to less than a year later and one of the new bulbs was having 'issues' in that it would work until it heated up a bit, then stop working. A sharp knock on the taillight assembly with my hand would bring it back but only briefly. Swapping the bulb between the taillights confirmed it was a bulb problem and not a wiring or bulb socket issue.
I installed another pair of the Sylvanias simply because they were easy to get locally. But looking at them closer, the first set of replacements had REALLY ugly soldering done on the filaments and posts (or whatever they are) while the new ones look great. There was also a dark spot and solder spatter inside the bulb right next to the filament that worked only occasionally. I still have the bulbs and will try to get pics if anyone is interested.
Now I'm certainly not going to start barking at Sylvania for a pair of $5 bulbs, but has anyone else had issues with them? I might start trying GE or Wagner bulbs in the future.
