Hello!
New here to BITOG.
I need some advice.
I have a 1999 Pontiac Grand Am 3.4L V6 with 138,000 miles that I have put Castrol Edge Syntec 5W30 in it since the day I got (30,000 miles ago). The crankshaft seal, rear main seal and oil pan gasket have started to leak some oil. Not surprising for a 15 yr old engine. Obviously this engine is too old to warrant replacing all these seals.
I want to know what would be the best oil to switch to that would help the seals, I was thinking about switching to Valvoline MaxLife High Mileage Full Synthetic. My grandpa said something about changing from 5W30 to something a little thicker to decrease leakage. Opinions on that? Will it hurt my MPG? I life in Ohio so we get very cold winters, can't go so thick it won't start.
Also, I have been a religious K&N oil filter user because for my 5K OCI the oil is always the cleanest with K&N. However, they are so expensive! Any suggestions on great filters but cheaper?
Thanks for the help!
CodyG
New here to BITOG.
I need some advice.
CodyG
