Originally Posted By: tig1
Originally Posted By: ottotheclown
Ever notice Mobil needs alot of explaining it could be this or it might be that, I have an uncle that does not have any trouble, I have used this for 31 yrs blah blah.Me I stay clear of any oil that needs to be explained. Oil is too simple these days keep it simple..
There are times engine noise does come from accessories, especially at start up. Inexperienced motorist may not realize that. I have learned a lot from the many years I have worked on engines. Some of it has even been helpful.
That's a good question. From my experience with pushrod engines (28 high performance cars, 16 engine builds and 6 race engines) this is not accessory noise. I have to admit this is my first OHC motor and the first with VVT and the differences are evident.
I am not a chemical engineer and have used M1 since 1989 in all of my "toys" and drivers. Up until this point, I have had zero issues with M1. I have never gone back to a conventional or synthetic blend once I have run M1. That is my question. The legend was that once you run a syn oil you should not go back. Screws up the seals, gaskets etc. Conceptually, I suppose it would be fine but I thought I would ask the experts.
Semi Syn oils were not even considereed in my circles. Once you run one stick with it was the mantra. Semi syns were considered a compromise. Things have changed and it is the 21st century. Ford specifies the MC blend and I figured I'd go with what I have in the past, which is a "better" oil and I start hearing strange noises. Maybe the Full Synthetic is too thin, too good, and not taking up tolerances until the engine heats up. Again, I am not an engineer. But noise is not neccessarily a death rattle. I know what that sounds like.
I guess I will find out the answer to my question once I tear it down in a few years and see what it looks like.
