I have a 03 BMW 330i with 131k miles on it. Last winter I noticed I had an oil leak. Being the weather was too cold and not wanting to pay the stealership for the repair I put a partial mix of High mileage Mobil 1 10w 40 to slow the leak. Prior to that I was running the Mobil 1 0w40. Due to Iowa temperatures hitting -30 degrees at times during the winter I did not want to run the straight M1 HM 10w40. So I drained half of the 0w 40 out and replaced it the HM variant. When spring rolled around I went to a straight HM 10w 40. The leak slowed but never stopped, finally got around to fixing the leak earlier this summer, leaky oil filter housing gasket. I now want to go back to the Mobil 1 0w 40. Is there going to be any problems switching from the Mobil 1 HM back to 0w 40. I have read some people say once you go High Mileage Oils your stuck with it. If that is the case my only other option is to do the mix again or go with the HM M1 5w 30 for the winter, however that is not rated ACEA 3.
