With a swaybar, the distance from the pivot (attached to the car frame) to the end link attachment is the moment arm or leverage it has when twisting the bar. Attaching further away from the pivot gives more leverage, making the bar easier to twist, which is a softer setting.
Many swaybars have multiple attachment points, giving them adjustable stiffness. For example, if they have 2 attachment points, they claim to be "2-way" adjustable. I think such a swaybar is actually "3-way" adjustable because there is no need to attach symmetrically. For example, attach one side (doesn't matter which) to the far point (soft setting), the other to the close point (stiff setting), and you'll get a stiffness in between the two settings.
Question: if you attached asymmetrically like this, would the bar still respond symmetrically to L and R body roll? I think it would.
The stiffness is measured in how hard it is to twist the bar from the end links. The end links can't tell how long their moment arm is. They can only tell how hard the bar is to twist. That torque is the NET result of the length of BOTH end link moment arms or attachment points.
For example, suppose the length of the short & long attachment points is 6" and 12" respectively. If both end links are attached to the long arm, that's 12" each, so each end link (L or R) moves the other through 24" of moment arm. If one of them is moved to the short attachment point, then the total is 6" + 12" = 18" of moment arm. Each end link moves the other through 18" of moment arm. Neither can tell whether its own side is connected to the 6" or the 12" point. If you're connected to the short side, then the swaybar twists more on the opposite side because it has a longer lever arm, and vice versa. Yet since the entire swaybar freely moves up and down (lubricated bushings), it is the total amount of TWIST that matters, which is the same either way.
I'm curious what you think... agree? disagree?
