suzuki gz 250...???'s @ oil
Palmyra, PA
I just traded my scooter on a 2009 Suzuki GZ250 w/ @ 1000 miles; the dealer did a complimentary service using Spectro 10w-40 conventional mc oil, so I am good to go for a while; this is an air-cooled single cylinder engine that uses a shared sump system...should I treat it the same as my Yamaha V Star 650 which is also air-cooled & shared sump (as far as using an oil with a beefy add pack or thicker 20w-50 oil)? thanks...
I'm running Rotella 15w 40 in my gz 250. I can tell when it shears as the shift gets notchy going into first around 3000miles. I am going to try amsoil 10w 40. Seems to do fine with 40wt.
I have a Yamaha Virago 250 and in the summer I always ran a 20w50 motorcycle oil. In the cooler weather I ran the 15w40 HDEO.
Hard to say if you should treat it like your 650 if you don't tell us what oil you use exactly in your 650 :-)
Generally, yes, you can treat them the same. Depending on what you have in the V-Star, though, the oil may be over-kill. As others have already said, I'd use Rotella, 15w40, or 5w40 Rotella T6 if you're feeling saucy, unless you have a lot of the other oil or it simplifies your life or something.
Pretty solid reliable motor, no need to overthink the oil choice, IMHO.
