If anyone has one of these and problems with it connecting to your peripherals properly or intermittent weird issues be advised that there is a firmware update tool from Microsoft.
I use this docking station for work and have had connectivity issues with my mouse/keyboard and dual monitor setup that would show up intermittently and the update fixed it. Just wanted to post it here in the event it might help others encountering the same issue.
Tool for download to update the Firmware: https://www.microsoft.com/en-us/download/details.aspx?id=46703
Download this file from the list: Surface_Dock_Updater_v2.22.139.0.msi
Run the file once downloaded to install the application and then run the application from your start menu called "Microsoft Surface Dock Updater"
During the update it will have you disconnect and re-connect the dock a few times.
![[Linked Image] [Linked Image]](https://images.techhive.com/images/article/2015/10/surface-dock-2-100620291-orig.png)
