My wife has a 1993 Chevy Lumina and it also takes the 3387A or ST3387A as listed in any application book. I put on a 3980, which is just a bit longer than the 3387A. But, as filter guy points out, this is not the recommend for your car. Thread size and gasket size are literally identical. On my Buick PA I have the Mobil 1 equivalent of the 3980. I looked in WIX website and the RECOMMENDED listing for that car is the 51040 WIX which is the short version, which has a nominal micron rating of 19, 7-9 gpm flow. The longer version of the 3387A, the 3980 crosses at the WIX number to be a 51036 with a nominal micron rating of 25, flow of 7-9 gpm. Interesting. You go longer with more capacity in the WIX 51036 but gave up a bit of tighter filtration. That really doesn't make any sense. With the longer filter, more Cubic Inch surface area, you should be able to get by with the tighter filter and still realize the 7-9 gallon minute flow. With the shorter filter I would have expected it to have a more porous filter media because of it's reduced filtering area.
