Supertech hurting seals?
I didn’t think so but someone on another forum did, figured I would see what others had to say. Thanks
The person on the other forum is one of the following.
1. Lying
2. Switched from conventional/synthetic blend to a full synthetic which can cause build up to be cleaned up around seals resulting in a already bad seal to start leaking because that build up which was blocking the leak is cleaned up.
3. Just now noticed a prior existing leak.
Supertech is not going to harm seals, no licensed oil is going to harm seals.
Since this fram filter fiasco super tech in general is taking a beating not Walmarts wrong doing.
Oil spills have been known to hurt seals.
