Supertech DEXRON III/MERCON
Virginia
I have a '97 Ford Taurus & was wondering if there were any thoughts on the Supertech Mercon ATF fluid? I've looked and couldn't find a specific post on the site. A few things about the Mercon V, but not this porduct.
Basically I did a trans line cooler drain & fill/swap using 2 gals of Supertech, and am planning on coming back in a couple of weeks and swapping out another 2 gallons in the same way only using Pennzoil this time, but I got to wondering what this fluid is like in comparison to other brands.
Anybody in the know?
(Since somebody's likely to talk about changing the filter, etc, I did an AutoRx tx on the trans, then actually replaced the pan and filter about 25K ago or so after 60K, so I feel pretty good that the filter is good and the magnets clean. I plan to do a pan drop in another 30K.)
There probably isn't enough difference to worry about, but if I were doing it I would stick with the same brand.
There is nothing wrong with either brand. Either one will serve you well.
