- Joined
- Oct 7, 2023
- Messages
- 11
Like the title says, does anyone know about the base stock for the super tech full synthetics?
I read somewhere that Warren is a big purchaser of EHCInformation is proprietary so it is not likely that we will ever find out. But Mobil’s EHC base stocks (Group II+) can be used to formulate Dexos approved lubricants.
I would like to know that also.I understand that EM's EHC can be combined with Group III base stocks to meet Dexos1 Gen 3. However, can Walmart legally market Super Tech Full Synthetic oil as a full synthetic (Group III) if the base oil used in the formulation is a combination of EM's EHC base stocks and Group III?
Mind you that Group I, II and III base stocks aren’t determined by the production process only by the resulting level of saturates, sulfur and the viscosity index.I understand that EM's EHC can be combined with Group III base stocks to meet Dexos1 Gen 3. However, can Walmart legally market Super Tech Full Synthetic oil as a full synthetic (Group III) if the base oil used in the formulation is a combination of EM's EHC base stocks and Group III?
Don't know the answer but it's good enough for Dexos spec. If you're concerned that your neighbors will dis you for using WM brands, try Costco Kirkland, same thing in a different bottle.Like the title says, does anyone know about the base stock for the super tech full synthetics?
Who said Super Tech Full Synthetic is using EHC?I understand that EM's EHC can be combined with Group III base stocks to meet Dexos1 Gen 3. However, can Walmart legally market Super Tech Full Synthetic oil as a full synthetic (Group III) if the base oil used in the formulation is a combination of EM's EHC base stocks and Group III?
Exactly. I’m wondering this also.Who said Super Tech Full Synthetic is using EHC?
It is a law afaik in Germany, i remember readind last year that Motul had to pay a pretty big fine for selling Group III oils as Vollsyntetisch in Germany.There are no laws in the US (or anywhere else besides Germany for the matter) regarding marketing terms such as “synthetic”. Just as there was no “lawsuit” in the Mobil/Castrol marketing dispute. I’m not even sure it’s a law in Germany or some sort of other requirement.
Makes licenses, specifications and approvals most significant.
Hypothetically yes, since there are no guidelines regulating the composition of synthetic oils. It has morphed into a term that is used to define performance level.I understand that EM's EHC can be combined with Group III base stocks to meet Dexos1 Gen 3. However, can Walmart legally market Super Tech Full Synthetic oil as a full synthetic (Group III) if the base oil used in the formulation is a combination of EM's EHC base stocks and Group III?
Legally ? What law(s) define "synthetic" ? One could argue that the addition of additives make it "synthetic".can Walmart legally market Super Tech Full Synthetic oil as a full synthetic....
Not really. It still means a process such as severe hydrocracking where you’re assembling precursors, not just “cleaning” the base stock. Chevron for example does not call their “Group II+” base a synthetic.Hypothetically yes, since there are no guidelines regulating the composition of synthetic oils. It has morphed into a term that is used to define performance level.
Synthetic still means synthesis.Legally ? What law(s) define "synthetic" ? One could argue that the addition of additives make it "synthetic".
True, the term does signify a certain amount of refinement, but there is ultimately no governance on how the term can be used for marketing finished products.Not really. It still means a process such as severe hydrocracking where you’re assembling precursors, not just “cleaning” the base stock. Chevron for example does not call their “Group II+” base a synthetic.
Correct.Chevron calls it Synthetic Technology.
