Lead was high in this sample.
Oil was is for 15 months.
Fram filter was installed by Lube Express. (Now I change my own oil & use ST filters.)
I make lots of short trips.
Engine is Toyota 3.0L 3VZE with 184476 mi.
I am now in the cleaning stage of Auto-RX, using ST 10W-40.
Oil Report
Blackstone Comments: "Lead was the only element out of line in the spectral examination of this oil. At this level, it is not high enough to show a problem, but does show more bearing wear than we usually see from this Toyota engine. It may be normal if you used any additives, or it may be from a particle streak through the bearings. If so, it will drop in subsequent samples. No fuel dilution, coolant, or moisture was present in this sample. The universal averages show typical wear from this type of engine after 5900 miles on the oil. Check back to monitor."
[ November 19, 2004, 03:11 PM: Message edited by: rugerman1 ]
Oil Report
