Originally Posted By: CapriRacer
I've had this stray thought floating around in my head for a while, so I'm going to put it down on paper (and by *paper* I mean electrons!), and let people take pot shots at it. Here's the premise.
This business about air containing water is a bunch of hooey! At least it is when it comes to explaining why nitrogen inflation is better then air! Water vapor (steam) behaves like an ideal gas (PV = nRT), just like all the other gases do - at the temperatures and pressures we are dealing with when we discuss tires.
Further, there is the partial pressure of gases law that states that you can treat gases like their individual components. So a tire filled with 100% nitrogen will gradually accumulate oxygen because the partial pressure of oxygen in the atmosphere is greater than partial pressure of the oxygen inside the tire. The same is true for water vapor.
The partial pressure of the water vapor inside a freshly air filled tire is greater than the outside air, so the water tries to migrate out - even when the air line is spitting out water and even when people use water based lubes to mount the tire.
Proof? Has any ever seen puddles of water inside on freshly demounted tire? You'd think that would be a common sight if water was the such a significant issue in the nitrogen vs air debate.
So take your best shot at this argument!! Let's see if it stands up to scrutiny.
OK, I'll take a stab at this one, and if you think I'm wrong, please speak up, contrary to current wisdom, I DON'T know it all.
You are correct on the law of partial pressures, ... to an extent.
First, the law of partial pressures only applies to gases within a common container, ie. atmosphere, a tire, a tank, whatever.
When you fill a tire with two constituents ie water vapor and O2, you do have two pressures WITHIN the tire, forming a total pressure, ie 35psi. Now lets fill that tire with 100% N2, single pressure 35psi.
Outside, you have air, with all it's partial pressures adding up to 0psi (gauge)
If you want to get complicated and use absolute pressure, then the tire has 49.7psi and the air is 14.7psi, but that's just unneeded complication.
No matter what the constituents of either container are, as long as it will hold pressure, then there can be no migration of the lower pressure to the higher pressure. Air can't infiltrate the tire when it's pressure is higher. In that instance total pressure is what matters.
Just as heat will migrate to cold, higher pressure will migrate to lower pressure. No migration of air can enter the tire until the atmospheric pressure is greater than the pressure inside the tire, no matter what the makeup of the gases involved.
