Do you guys see any problems with using the Super Tech Mercon V? Manual says Nissan Matic-D or Dexron III. Car is 2003 Nissan Sentra SE-R 4AT. 65,000 miles. Dealership did an ATF flush at ~30,000 as recommended by manual.
The ST MV bottle says compatible with DexIII, DexVI, Matic-J.. and a bunch of others. Says on the back that this is a synthetic blend ATF.
This is for a car that currently sees about 5-7K miles per year. Since it's so cheap, I plan a drain and fill once a year.
