Funny that you posted this today. I just received BS results for Virgin 5W-20 and posted it too. Thanks for sharing.Nothing out of the ordinary here. I do wonder if they made any changes going to 20K miles?
Thanks for the VOA, both of you! I noticed this 10k supertech has a higher TBN than the Advanced you posted. New around here, first post actually. Not an expert by any means but iid think, from what ive read around here, your 20k advanced supertech sample should have had a higher TBN than this regular 10k supertech sample, right? EDIT: im an idiot. This is a 20k sample. SorryFunny that you posted this today. I just received BS results for Virgin 5W-20 and posted it too. Thanks for sharing.
On face value and common sense logic, I'd agree. But TBN doesn't have to be a linear measure across all oils. It may take longer to deplete (for example sake and not accurate representation) Mobil1 EP 5w30 with a 7 TBN than say Valvoline Blend 5w30 with the same TBN.Thanks for the VOA, both of you! I noticed this 10k supertech has a higher TBN than the Advanced you posted. New around here, first post actually. Not an expert by any means but iid think, from what ive read around here, your 20k advanced supertech sample should have had a higher TBN than this regular 10k supertech sample, right? EDIT: im an idiot. This is a 20k sample. Sorry
Thanks for the knowledge! Much appreciated.On face value and common sense logic, I'd agree. But TBN doesn't have to be a linear measure across all oils. It may take longer to deplete (for example sake and not accurate representation) Mobil1 EP 5w30 with a 7 TBN than say Valvoline Blend 5w30 with the same TBN.
Comparing this to the High Mileage ST full synth, it almost seems like the HM has a slightly beefier additive package. I was considering going to the Advanced Full Synth 0w-20 in our '18 CR-V for its next oil change, but I may just throw in the HM 0w-20 (even with only 24k miles on the vehicle).
