Originally Posted By: Drew99GT
http://wattsupwiththat.com/2015/07/23/the-2015-el-nino-is-shaping-up-to-be-a-big-one/
http://www.vox.com/2015/8/17/9164499/el-nino-2015
They're really hyping this on up and relating it to "climate change" (
rolleyes).
The great Joe [censored] says that after this El Niño and subsequent La Niña, global temps should be more accurately measurable.
http://notrickszone.com/2015/08/02/#sthash.LMtNT7Pm.dpbs
If you do not think climate change and warmer ocean surface water are related.......Then I am not going to try to explain it to you.
Please, explain it to me. It can't possibly be related to differential heating of the oceans by the sun...
I don't claim to understand the complexities, nor the arguments for (the majority) and against (the minority) global climate change fully (or even partially, really,) but from the article you linked:
Quote:
The reason is simple: As humans put more greenhouse gases in the atmosphere, we're trapping more and more heat on the Earth's surface. But more than 90 percent of that extra heat is absorbed by the oceans. So subtle interactions between the ocean and the atmosphere can make a big difference for surface temperatures.
When conditions in the Pacific are neutral, more of that heat is trapped beneath the ocean surface. When a strong El Niño hits, more of that heat is released, essentially transferred to the surface. That's why the Earth's average surface temperatures reached new highs in 1998: due to the combination of global warming and an extremely strong El Niño.
