I belong to various other forums, and never have any trouble using the SEARCH function on any of them. However, on BITOG I can NEVER get good search results!
For example, I am looking for information about what battery to use for my 12v back up sump pump in the basement. It is a Basement Watch Dog pump and battery (24EP6) which was in the house 16 months ago when we purchased it. My main sump pump failed several days ago, and the back up pump worked well. The battery is showing it is weak, and I have tried charging it and filling the cells with distilled water. They were a bit low. I replaced the main sump pump, and have the back up on standby again. I want to get a better battery for it.
I want to see what other batteries can be used or that are suggested to use. When I put "sump pump battery" into the SEARCH engine on BITOG and check all forums, I get results including electrical shock, best long term fuel storage, broken drive belt, using E85 flex fuel, and a whole bunch of other off the wall results. I also get results of all the replies within the found topics. Broken drive belt might show up 12 times in the search result if there has been 12 replies!
What am I doing wrong? I have seen others post that say do a search when someone comes on the forum looking for information. I have tried other searches such as "best oil filter", etc and still can never come up with good results. Always have the multiple results showing all of the replies from a topic, and can never narrow down my results to what I am actually looking for.
TIA!
TIA!
