There's a few videos out there (youtube, etc.) of people demonstrating the flow of cold oil at below freezing temperatures, but I've never seen anyone test the flow of oil at normal, i.e., "room temperature".
I'm guessing that nobody has done a "warm" oil test because they think that all oils (i.e., 0W, 5W, 10W, etc.) flow pretty much the same if the ambient temperature is 60, 80, or even 100 degrees. The motor might be cold...but on startup, all oils will flow and therefore, reach all moving parts at the same time regardless of grade?
I'm skeptical that's true, but I'd also be interested in testing that theory. I work at a College that, of course, has an auto shop, Chemistry lab, Physics lab, etc. I'm thinking the instructor(s) might find this an interesting test so I'll bet I could recruit someone(s) to help me.
Given the resources I have at my disposal, can you offer some suggestions on how I might set up for such a test(s) so the end results are accurate? I welcome your suggestions.
Thank you,
Ed
Thank you,
Ed
