Suggestions for DIY Throttle body Bracket?
Lima, Ohio, USA
my neon has an Iceman CAI installed by prev. owner (My brother).
instead of using the brackets that seem to come with most CAI kits, he enlarged the hole @ the input end of the factory airbox, and ran the intake tube through it. (looked stock with the hood up - might have been trying to sneak it through smog inspections, or he might have gotten the intake second hand, IDK.)
so i want to take the airbox out of the equation, but would need to find/fab up some kind of support brackets for the Throttle Body.
(in the Stock intake system, The Throttle Body Bolts Directly onto the Air Filter Box, and the Filter itself is a "Barrel" type, that slips over the rim of the Throttle Body )
I would need something similar to what you see in the linked K&N install sheet, parts c&d on the diagram, and steps 15-19.
http://www.knfilters.com/instructions/69-2520_inst.pdf
suggestions? i have mostly basic hand tools. the only power stuff would be a drill, antique Dremel, and a jig saw. fairly comfortable with wood work, not as much with metal, but i can learn.
I Posted this same question over in a neon Specific Forum 3-4 days ago, haven't gotten any responses back(50 views, zero responses), so I'll try my luck over here.
Maybe use some of that perforated mounting strap. Or you may find some brackets on ebay.
Looking at the K&N brackets (one on each side of the TB) they appear to be very stout which makes sense. I would be concerned about using up something lightweight that would fail causing your throttle cable to suddenly bind, stick or become unresponsive.
Can you possibly trim back more of the airbox (not enough to compromise it's integrity) allowing the skeleton to serve as your bracket
If it was my car I would try to find a used stock airbox and plenum or go with a different setup like the K&N
