Suggestion for DI cleaner for e85 fuel.
I only run E85 fuel in my 915whp TTRS. This car utilizes DI and PI from the factory and we have had many failed engines that were a result from a DI failure.
I am looking for a fuel additive that I can run with E85 to keep the DI's clean and running good. I treat these injectors as a service item and have them flow tested and cleaned every year but I am looking for something that I can add to the fuel every few fill ups.
Amsoils cleaner is known to be good, Could try that. But i doubt it would need it that frequently. I'm sure once a year is fine.
I always go with Liquimoly DI Jectron (w/PEA). Email Liquimoly and see what their take is on the ethanol use.
I would try
2 stroke oil rated for E85, for better lubrication.
And a better fuel filter solution.
Otherwise Red Line SI-Alcohol, no clue if it has any effect though.
