Good Morning - I have a 2003 Dodge Caravan with 3.3 liter V6, 170,000 miles. I started the engine and immediately smelled gasoline. I backed out and saw a huge puddle where the car had been parked. Fuel was pouring out under the car. I cut off the engine quickly and checked under the car. The fuel seems to be coming from a black plastic line about 5/16" in diameter. I plan to put the car on jackstands or ramps to get a better look. The line seems to run from the fuel tank to a connector located about under the drivers seat.
Is there some sort of quick connector or compression fitting that I can use to replace the damaged section of line? I really don't have a way to drop the tank. I could just have the car loaded on a roll back and taken to a local garage.
So what do you all think? Is this a shade tree mechanic job or just let the garage do it? I was a bit freaked about the sudden, massive fuel leak. If this happened when the exhaust and convertor was hot, I might have had a fire.
Thanks in advance for any advice.
