I have a 06 Subaru Legacy Wagon 2.5i/NA motor.
I have used Pennzoil Platinum 5W30 from the start. The car runs great with the PP but it does burn 1QT on a 5000K OCI. I was told that the 2.5 motor will burn synthetic oil because they are thinner than regular oil. On my last oil change, I went with Castrol Synthetic Blend 5W30 and I have only burned about 1/2QT on this OCI.
The car runs smoother on the PP and I am wondering if there is any reason to not run the PP? I like the Castrol and the cold starts are fine with it but with the PP the motor purred a little more purry than with the Castrol.
Is it bad to burn that much oil...or is it bad, only if you don't check your oil levels?
Thanks in advance!
Thanks in advance!
