Anyone have issues with the OEM Subaru filter leaking from the seal. This filter has a O ring of sorts. looks kind of triangular rather than round and only has about 1/16" crush before the metal outer can edge makes contact. It screwed on too easy in my option and the metal bottomed out before it felt tight. It did not gradually tighten like all the flat gaskets I have used, it bottomed rather abrupt. Anyway looked ok during the normal couple minute leak check but after a trip to town it is dripping very slow from the filter seal. Is it common? I just put on a XG7317 and it is not leaking. The OEM looks fine, no visible damage so it this just a fluke or??? I have a couple more but not if it's just going to leak again. I should add the rubber felt pliable as I wondered if it was old stock that had hardened.
