Subaru BITOGers
What problem are you trying to solve by going with the wrong sized filter? IF under warranty, I wouldn't, If not, knock yourself out, but you aren't gaining anything, even if there is more filtering material. Nothing measurable anyway. If you do, triple check bypass setting is correct.
I don't know if it applies to the 2.5L outback, but I think Subaru switched to a shorter oil filter on a turbo model or two because the filter was very close to the exhaust and got heat soaked.
