Mobil 1 Filter M1-110
Tbilisi, Georgia
Hello,
I've got 2003 Nissan Pathfinder SE 4wd with VQ35DE engine.
I've been using Mobil 1 Extended Performance 5w30 with M1-108 synthetic oil filter. M1-108 was recommended by Mobil 1.
Recently I checked and their recommendation now is M1-110 or M1-110A.
I don't know if it's just a typo from their side or they have specific reason to recommend M1-110/M1-110A instead of M1-108/M1-108A.
M1-110 is a longer filter but has the same thread.
Do you have any experience with it?
Should I switch to it or stick to M1-108A?
I use the 110 on Nissan where there is room, such as Altima and Rogue.
I service a friends 2015 Sentra and use the shorter 108 because it installs vertically at the bottom of the engine.
The 110 would extend too low.
The same holds true for Fram, etc.
Use the M1-110(A)
Most people on here use the longer filter anyway, so you're in good company
If my car spec'd a shorty, I'd use the longer filter.
If Mobil recommends the longer -110/110A then it's a win-win.
