Originally Posted by Farnsworth
Originally Posted by CR94
Originally Posted by ZeeOSix
... It's the oil trapped between the filter media and the can that I'm talking about. It does not "fall out" of the filter when the base is turned down. ...
The reason it does not flow out through the media to the center hole is an interesting but neglected topic.
I think it always does given enough time. When the center tube drains out there is air. I think there is the adbv, vacuum, and capillary attraction in the media preventing filters to drain out the same. The clean side chamber is also pretty small so the pressure on the media is pretty small. Without an adbv of course it will drain out fast. Some medias may drain through faster than others. Some may never seem to drain but given enough time they will.
The test I did on the PureOne sat for a whole week with the base down, and all the oil trapped between the media and can was still in the filter.
